Hey guys, first post here.
I have created multiple sheetmetal parts with many #9 holes for 3/16" rivets. Originally the holes were #30 but I changed them all to either #29 for 1/8" rivets or #9 as previously stated. I created these using the hole wizard with simple thru holes, then later edited the feature to create larger holes.
Now when I am creating my drawings a couple parts have incorrect holes displayed. For example, I have one part that has 3 hole groupings. In the model, all three groupings are #9 holes. However in the drawing 1 of the groupings has visually smaller holes. When I hover over the smaller holes the tool tip says #9 as it should, but when I add a hole callout it says the hole is .125". The weirdest part is that the hole was never exactly 1/8", it was #30 or .1285". 3 of my 7 parts are doing this. I have tried forcing an update, deleting and recreating the views, and starting a new sheet all with no luck.
Adam
P.S. : I am using SolidWorks 2014
Hi Adam,
it may be because the lay-flat is a different configuration. When you alter a hole wizard feature it usually shows a dialog to some effect about how you want it to control configs and the change you just made. It may be that the changes made in one configuration are not applying to the lay-flat.
