NZNamita Zaware10/07/2017
Hello all,
I have a mechanical assembly in which multiple instances are created for few parts. In the electrical design of the same assembly, different wires go to the different instances. Because of  this, I have created different symbols for the instances in 2d electrical design. So, each instance is an electrical component in 2d electrical design.
I want to route wires from 2d to 3d.
While doing so, only one instance of mechanical model gets assigned or associated as electrical part. The other instances can not be declared as electrical part.
This results that I can route wire connecting to single instance only. How should I route wire for other instances?
Should I make changes in mechanical assembly?
Regards,
Namita Zaware
