I want to rotate tor text 90 degrees permanently so that it aligns to one row and does not occupy the next row.
Hi Jesusa,
Just select the text and rotate it through modify tab on the upper ribbon.
In the project configuration, the font tab shows properties of the font used for different purposes.
It has origin-destination arrows field. But here, the rotation angle of the text can not be specified. Look at the image below.
So I think..only option remains is to rotate the text manually through modify tab.
regards,
Namita Zaware
The problem with manually rotating it is that when you add another reference (origin-destination) it inserts it unrotated.
Hi Jesusa,
regards,
Namita Zaware
