2 Replies Latest reply on Jul 8, 2017 3:27 PM by Roman Mettler
    drag and drop from taskpane
    Roman Mettler
      Good aftenoon!
      im building a c# plugin, and need to implement drag&drop operations, the scenario is like:
      my taskpane have a treeview with parts, and i need to drop them in assembly,
      iv set a breakpoint in "Doc_FileDropPreNotify" but never get fired...
      any help would be appreciated.
        • Re: drag and drop from taskpane
          Amen Allah Jlili
          We are NOT wizards. We need code Mr. Roman
              Roman Mettler
              Hello Mr. Jlili, i didnt thought that was important the code, but was nice that you remember me that, now the question is:
              what parts of the code should i post here?
              in AssemblyEventHandler class:
              override public bool AttachEventHandlers()
                   doc.FileDropPreNotify += Doc_FileDropPreNotify;
                   return true;
              private int Doc_FileDropPreNotify(string FileName)
                    System.Windows.Forms.MessageBox.Show("DropDetected");  -> never run with dragged files from my treeview;
                    return 0;
              in taskpane class:
              fdtv_projectTree.AllowDrop = true;
              private void fdtv_projectTree_ItemDrag(object sender, ItemDragEventArgs e)
                    var node = (FControls.FDirectoryTreeNode)e.Item;
                     ((FControls.FDirectoryTreeView)sender).DoDragDrop(node.Path, DragDropEffects.Copy);
              private void fdtv_projectTree_DragEnter(object sender, DragEventArgs e)
                   e.Effect = DragDropEffects.Copy;
              Hope this can clarify what im trying to do, drag operations from the native explorer treeview taskpane are workinf and the event Doc_FileDropPreNotify is reached...
              can be something related with permissions?
              thank you in advance,
              Bruno Frade.
