Help me. how to use RunMacro in Excel VBA
Result is see image.
SwApp.RunMacro FilePath, "a.swp", "aaa" , don't sub aaaa
in excel vba code is
Private Sub aaa()
Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
Set SwApp = GetObject(, "SldWorks.Application")
Set SwModel = SwApp.ActiveDoc
Dim FilePath
FilePath = ThisWorkbook.Path & "\" & "a.swp"
Debug.Print FilePath
'SwApp.RunMacro FilePath, "a.swp", "aaa"
SwApp.RunMacro FilePath, "a1", "aaa"
in solidworks API
Private Sub aaa()
Set SwApp = Application.SldWorks
Dim SwSelMgr As SelectionMgr
Set SwSelMgr = SwModel.SelectionManager
Dim SwDispDim As DisplayDimension, SwDim As Dimension
Set SwDim = SwModel.Parameter("D1@Sketch1")
Debug.Print SwDim.FullName
MsgBox SwDim.FullName & "=" & SwDim.Value
Stop
2017 SOLIDWORKS API Help - Microsoft Visual Studio Tools for Applications Requires Microsoft .NET Framework 3.5 http://help.solidworks.com/2017/English/api/sldworksapiprogguide/GettingStarted/VSTA_Dependency_on_DotNet_3Dot5.htm
a.swp runmacro b.swp, result is true
in a.swp, code is
Dim filename As String
filename = swApp.GetCurrentMacroPathName
filename = Left(filename, InStrRev(filename, "\")) + "b.swp"
boolstatus = swApp.RunMacro(filename, "b1", "main")
In b.swp, code is
MsgBox "ffffffffffffffff"
swApp.SendMsgToUser "RunMacroSub1:main() called"
