Curious if anyone has figured out how to use the "Number" column in the Wire Manager, and if so what is it's purpose? I don't see anywhere on a wire type to change it, I thought maybe it was a way to manually reorder the wires within a group, but I don't see where I have any control over the number.
The number field is only relevant to the "multiple add" wire style group, and controls the order in which the wire styles are displayed when using the "Draw multiple wires" command in a schematic. The up/down arrows in the manager will become active when a multiple wire style group is selected from the list in the left-side panel, and allow you to more easily adjust this order (as opposed to opening the properties of each wire style individually).
