Hi !
I joined my project as a zip here.
I have those 3 parts ( one is twice in the assembly ) , I sent those file to a company to 3d print it but the piece don't fit together.
Probably because of the precision of the printer. But the major issue is that all my piece are fitting with each other exactly.
How can I add some wiggle room between the piece ?
could you attach a dumb solid? or add some images to reference the areas that interfere? I am unable to open your asm as I believe it is a future version, but there are multiple methods to add clearance between mating parts.
In general, any part that is being manufactured needs to allow for some amount of clearance between mating parts to accommodate the accuracy of the method used to produce the part. If you model your parts size-for-size then you will always have an issue. You can either start with the high and low ends of your tolerance threshold and adjust based on your prototypes. Or, design your parts size-size and identify critical features/areas that need to maintain a specific size/form and then apply your clearance to the other areas that are not as critical.
