Re: playing back recorded macro fails...
Peter Brinkhuis Jul 5, 2017 7:56 AM (in response to Nick Middleton)This works for me:
Sub ChangeChamferPrecision()
Dim swModel As ModelDoc2
Set swModel = swApp.ActiveDoc
Dim boolstat As Boolean
boolstat = swModel.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingAngularDimPrecision, swUserPreferenceOption_e.swDetailingChamferDimension, 0)
Maybe only changing the object types to the SolidWorks types will do the trick for you.
If you need to change more settings, the help is pretty detailed. It just misses code samples pretty often, but you have the basics from the recorded macro already.
2015 SOLIDWORKS API Help - Document Properties > Dimensions > Chamfer
Nick Middleton Jul 5, 2017 8:46 AM (in response to Peter Brinkhuis)Hi Peter,
I have just copied that code and i cant get it to work...
Do I need to keep the code that is there when creating a new macro (to paste into)?
Nick Middleton Jul 5, 2017 8:48 AM (in response to Nick Middleton)Im not sure if this makes much difference but I am using sw 2016 sp4
Peter Brinkhuis Jul 5, 2017 8:52 AM (in response to Nick Middleton)You only need the code I posted for it to work. You can add as many subs as you want in a macro though, press F5 or press play to run only that sub.
Are you sure the macro runs? You can add a break point halfway and run it to see if it pauses there. You can also try to add this to print true if the value was set and false if it wasn't set properly:
debug.print boolstat
Nick Middleton Jul 5, 2017 9:37 AM (in response to Peter Brinkhuis)Hi Peter,
I dont really understand all the code, however I can understand that certain bits that come up are for particular operations.
the macro I recorded still works as I have a button to change both the normal and chamfer angle precision from no zeroes to 8 zeroes and vice versa.
I can see clearly the normal angle precision (trailing zeroes) coming and going as I press the appropriate buttons. the chamfer part of the macro does nothing....
To be honest Im losing the will to live as I spent ten days on a piece of code that should take less than five minutes. this code recognised the drawing title ammended the trailing zeroes from smart to show. I also added the arrows to change from outside to inside.
I purchased the automating solidworks with macros (2017 because that is what I am personally running at home) book with the outside hope that I can get one macro to work my way one day.....
writing macros is way to painful :-(
Peter Brinkhuis Jul 5, 2017 9:49 AM (in response to Nick Middleton)I agree, programming can be painful The snippet of code that I posted above took me only a few minutes though. Just keep trying and keep reading. Sometimes you might feel you're missing the basics, so reading that book will really help.
You said you have different buttons for macros. Have you selected the correct method in the macro button properties? In my example here, I selected the IncreaseLength sub within the Main module. You can create one macro with a few subs and hook a button to each sub.
Can you post all of your code?
Nick Middleton Jul 5, 2017 10:17 AM (in response to Peter Brinkhuis)***********************************************************
' C:\Users\nickmiddleton\AppData\Local\Temp\swx3024\Macro1.swb - macro recorded on 07/05/17 by nickmiddleton
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingAngularDimPrecision, swUserPreferenceOption_e.swDetailingAngleDimension, 0)
Dim swApp As Object
Dim Part As Object
Set swApp = _
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingAngularDimPrecision, swUserPreferenceOption_e.swDetailingAngleDimension, 7)
This is a newly created set of macros just for normal angle precision. Both sad face and purple face buttons work well and trigger the desired output.
When I try the Exact same thing with Chamfer precision it does less than nothing.
I have cut and pasted your code with no luck. ( i am not convinced its because i am running sw16sp4)
any further help very much appreciated
Peter Brinkhuis Jul 5, 2017 10:25 AM (in response to Nick Middleton)Can you run my code again, add a break point at the last line (end sub) and see what the boolstat value is by adding a watch? That does the same thing as adding debug.print. We just need to know if it doesn't execute correctly or if you don't see any result.
Nick Middleton Jul 5, 2017 10:38 AM (in response to Peter Brinkhuis)-
Nick Middleton Jul 5, 2017 10:44 AM (in response to Nick Middleton)One thing I have just noticed after running my recorded code for chamfer angle precision is this.
in the actual preferences the box says None. and the actual drawing still has an unrefreshed collection of zeroes. rebuilding does not clear it either.
if I click on none just for the sake of choosing none again.... the drawing changes. possibly a bug?...
Nick Middleton Jul 5, 2017 1:50 PM (in response to Nick Middleton)Hi Peter,
I just tried the same macro on my 2017 at home and still have the same problem.....
Not really sure what to do other than just wait for book to arrive.
Peter Brinkhuis Jul 6, 2017 8:07 AM (in response to Nick Middleton)I just played around with a few dimensions in SolidWorks. What's probably causing this is the fact that SolidWorks just doesn't show any digits when there is nothing to show. A 45 degree chamfer will always be shown as 45 and not as 45.000000000.
A way around that is to go to Options > Document Properties > Dimensions > Trailing zeroes (bottom left) and set it from Smart to Show.
Nick Middleton Jul 6, 2017 8:18 AM (in response to Peter Brinkhuis)sadly this trailing zeroes is exactly what has triggered the requirement to use the chamfer precision tool :-(
i automated it to change trailing zeroes from smart to show in order to get for example a 20mm diameter to read 20.00 in order to register a requirement in the tolerances. one thing i did notice today is you can mutiple select normal dimensions and change how many dp there are and it will update all selected dims.
when you try and do the same with these blasted chamfer dimensions
it will not update the selected chamfer dimensions.
I think I will just write this off as a glitch that cant be fixed. I get paid to mechanical engineer not fault find computer programming enigmas.
its just rubbish when something that should be so easy is so difficult to fix.
thanks for your feedback though. it makes me realise that I have at least been trying the right things...
