The goal would be to have it auto select the correct direction so a design table would be able to control the dimension correctly
If you're doing a design table then you'll need to add a plane or a sketch and measure from there
See Zero Dimension Flips Direction. Is it possible to predict the behaviour?
Hi Ryan
Try an offset
