Hi
Please somebody answer me.
power semiconductor connect in circuit with screw or terminal usually.
my question is how to draw & use the symbol , is there any connection point & circuit, because wires is not connect directly to semiconductor but with screw & terminal
as shown in SKKT92 thyristor sample attached file.
i confuse seriously please help me anyone
thank's to all
Hi Er,
All you need to do is- Draw two symbols in line diagram. First symbol is for semiconductor and the second one is for terminal. However the electrical wire/cable needs to be attached to the terminal symbol only.
By doing this, you will be able to insert two separate models in 3D assembly for semiconductor and terminal. While routing the wire in 3D, it will get automatically routed to the terminal.
I hope, this will solve your problem.
Regards,
Namita Zaware
