I would like to save an anchor point for the rev block so that when a new sheet format is applied, the rev block moves to the anchor point defined when the sheet format was saved. However, when I save my sheet format (defining the anchor point for the rev block first), and try to use it in a new template, the anchor point is not pulled in with the applied sheet format, and the rev block is not in the correct place. I always have to manually redefine the anchor point, while not difficult, it would be nice to have it automated for others I am creating the formats for.
Casey,
Are you updating both the *.drwdot Template files & the *.slddrt sheet formats? New forms pull "Templates" while updating/changing the sheet you normally use "Sheet Formats"
