Re: Hole Table: Possible to choose ALL holes without individually selecting each?
Dan Pihlaja Jun 30, 2017 11:59 AM (in response to Nick Sorenson)If you select the SURFACES that the holes were placed on, then the table grabs every related feature.
Sometimes you can get unexpected additions to your hole table that way (like a slot feature that you didn't intend to add to the table), but if that happens, then you can just remove those items from the list.
S. Casale Jun 30, 2017 1:01 PM (in response to Dan Pihlaja)BAM I learned something new!
Rick Becker Jun 30, 2017 4:37 PM (in response to Dan Pihlaja)Dan Pihlaja wrote:
I really need to start a post asking for bitches and fixes for the hole table.
I recently did a hole chart and WANTED the slots in it. Impossible to get what I needed automatically, easily or quickly.. Had to learn how to jump rope and add what I wanted to a general table and make it look like a hole table just to get the correct info to the shop floor.
Thanks for listening Dan.
Dennis Dohogne Jun 30, 2017 12:07 PM (in response to Nick Sorenson)Dan gave you the right answer, just pick on the surface and then Inset -> Tables -> Hole Table.
The default table works, but is easy to customize for easier interpretation. Here is an example of one I did recently. I moved the size column from the fourth from left to the second from left position, grouped the sizes, and added another column for notes. I also moved the tags to where they were not on top of object lines and to make it very clear which hole they were referring to. My machinist loved it.
Mohit Parmar Jul 1, 2017 10:49 AM (in response to Dennis Dohogne)helpful
Kelvin Lamport Jun 30, 2017 12:40 PM (in response to Nick Sorenson)2015 SOLIDWORKS Help - Hole Table (Insert) PropertyManager
Holes
Select individual hole edges, or select a model face to include all the holes in the face.
Edward Poole Jun 30, 2017 3:27 PM (in response to Kelvin Lamport)That's the way I learned it. Grab the face.
Wing Hoe Tan Mar 12, 2018 10:20 PM (in response to Nick Sorenson)I would like to revive this thread with a follow up question.
For the case where holes are on raised bosses, is there a way to select all at once? I have found that I need to individually select each individual boss face. I have also tried to create a plane but the hole table function does not recognize planes.
Wing Hoe Tan Mar 13, 2018 10:40 PM (in response to Dan Pihlaja)Hi Dan, this works great!!! Thank you.
With this method, I was able to grab holes on different planes!
