Hi Every one
I am creating custom signs.
I used the Solid Works "sketch entities / text command.
How can i make the letters larger? I used the largest font possible 72 but i need to make it bigger.
I also want to keep the center of the letter "O and e" is there away to keep this part?
thanks
Ken
Hi Ken,
72 might be the largest in the list, but you can manually type in other sizes, the same is possible with the units.
For letters that don't create dangling bodies you can use other fonts.
Stencil type fonts for example are ideal Fancy > Stencil, Army fonts | dafont.com Just download, extract then right click and 'install'
There are other sources out there, and not all suitable fonts are necessarily catergorised in stencil.
