IntersectCurve in VBA - decide between real and possible intersection points
Question asked by Andreas Killer on Jun 30, 2017
Alright, maybe someone has an idea to solve this.
After I found the solution to get IntersectCurve to work here
http://my.solidworks.com/reader/forumthreads/207972/intersectcurve-in-vba
I cleaned up my code and have written a universal Function GetIntersection to return the intersection points of 2 sketch segments, works AFAIK pretty good.
If I look at 2 splines, the function return only the real intersection points.
But if I look at e.g. a line and a spline, the function returns the real and possible intersection points.
You can execute Sub Main below with an already opened sketch, it creates a line and a spline and the intersection points between both.
But only one point really intersect both.
For completeness (and followers) I attach also my whole code, which includes examples for Spline-Spline, Spline-Arc, two arbitrary items.
For "normal elements" like lines, arcs, circles, etc. I can think of a method by myself to calculate if a point is really located on the element... a lot of code.
But I wonder if there is a more simpler way using the API of Solidworks to decide between real and possible intersection points.
Any ideas?
Andreas.
Option Explicit
Sub Main_IntersectCurve_Line_Spline()
  Dim swSketchMgr As SldWorks.SketchManager
  Dim swSketchSegA As SldWorks.SketchSegment
  Dim swSketchSegB As SldWorks.SketchSegment
  Set swModel = swApp.ActiveDoc
  Set swSketchMgr = swModel.SketchManager
  Dim pointArray As Variant
  Dim Points() As Double
  'Important:
  'Snapping off!
  Dim Snapping
  Snapping = swApp.GetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchInference)
  swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchInference, False
  'Add created sketch segments directly to the SOLIDWORKS database!
  swSketchMgr.AddToDB = True
  ReDim Points(0 To 14) As Double
  Points(0) = 0.03
  Points(1) = 0
  Points(2) = 0
  Points(3) = 0
  Points(4) = 0.04
  Points(5) = 0
  Points(6) = 0.03
  Points(7) = 0.08
  Points(8) = 0
  Points(9) = 0.06
  Points(10) = 0.04
  Points(11) = 0
  Points(12) = 0.03
  Points(13) = 0
  Points(14) = 0
  pointArray = Points
  Set swSketchSegA = swSketchMgr.CreateSpline(pointArray)
  Set swSketchSegB = swSketchMgr.CreateLine(0.03, 0.04, 0#, -0.045, 0.08, 0#)
  pointArray = GetIntersection(swSketchSegA, swSketchSegB)
  If IsNull(pointArray) Then
    MsgBox "No intersection"
  Else
    Debug.Print "Points:"
    Dim i As Long
    Debug.Print "X", "Y", "Z", "K"
    For i = 0 To UBound(pointArray) Step 4
      Debug.Print pointArray(i), pointArray(i + 1), pointArray(i + 2), pointArray(i + 3)
      swSketchMgr.CreatePoint pointArray(i), pointArray(i + 1), 0#
      swModel.SketchAddConstraints "sgFIXED"
    Next
  swModel.ClearSelection2 True
  'Clean up
  swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchInference, Snapping
  swSketchMgr.AddToDB = False
Function GetIntersection(ByRef swSketchSegA As SldWorks.SketchSegment, ByRef swSketchSegB As SldWorks.SketchSegment, _
    Optional ByRef RealIntersection, Optional ByRef PossibleIntersection) As Variant
  'Returns an array of doubles containing the x, y, z location of the tessellation points and a code for each point
  '  Null if no intersection is found
  Dim swCurveA As SldWorks.Curve, swCurveB As SldWorks.Curve
  Dim Astart() As Variant, Aend(), Bstart() As Variant, Bend() As Variant
  'Assume failure
  GetIntersection = Null
  Set swCurveA = swSketchSegA.GetCurve
  If Not GetStartEndPoint(swSketchSegA, Astart, Aend) Then Exit Function
  Set swCurveB = swSketchSegB.GetCurve
  If Not GetStartEndPoint(swSketchSegB, Bstart, Bend) Then Exit Function
  On Error GoTo ExitPoint
  pointArray = swCurveA.IntersectCurve(swCurveB, Astart, Aend, Bstart, Bend)
  GetIntersection = pointArray
  'How can I decide between real and possible intersection points here?
ExitPoint:
End Function
Function GetStartEndPoint(ByRef swSegment As Object, ByRef StartPoint, ByRef EndPoint) As Boolean
  'Based on https://forum.solidworks.com/message/393341
  Dim swSkPoint1 As SketchPoint
  Dim swSkPoint2 As SketchPoint
  If TypeOf swSegment Is SketchSegment Then
    Select Case swSegment.GetType
      Case swSketchSegments_e.swSketchLINE
        Dim swSkLine As SketchLine
        Set swSkLine = swSegment
        Set swSkPoint1 = swSkLine.GetStartPoint2()
        Set swSkPoint2 = swSkLine.GetEndPoint2()
      Case swSketchSegments_e.swSketchARC
        Dim swSkArc As SketchArc
        Set swSkArc = swSegment
        Set swSkPoint1 = swSkArc.GetStartPoint2()
        Set swSkPoint2 = swSkArc.GetEndPoint2()
      Case swSketchSegments_e.swSketchSPLINE
        Dim swSkSpline As SketchSpline
        Set swSkSpline = swSegment
        Dim swSkPoints
        swSkPoints = swSkSpline.GetPoints2
        Set swSkPoint1 = swSkPoints(0)
        Set swSkPoint2 = swSkPoints(UBound(swSkPoints))
      Case swSketchSegments_e.swSketchELLIPSE
        Dim swSkEllipse As SketchEllipse
        Set swSkEllipse = swSegment
        Set swSkPoint1 = swSkEllipse.GetStartPoint2()
        Set swSkPoint2 = swSkEllipse.GetEndPoint2()
      Case swSketchSegments_e.swSketchPARABOLA
        Dim swParabola As SketchParabola
        Set swParabola = swSegment
        Set swSkPoint1 = swParabola.GetStartPoint2()
        Set swSkPoint2 = swParabola.GetEndPoint2()
      Case Else
        Exit Function
    End Select
    ReDim StartPoint(0 To 2)
    StartPoint(0) = swSkPoint1.X
    StartPoint(1) = swSkPoint1.Y
    StartPoint(2) = swSkPoint1.Z
    ReDim EndPoint(0 To 2)
    EndPoint(0) = swSkPoint2.X
    EndPoint(1) = swSkPoint2.Y
    EndPoint(2) = swSkPoint2.Z
  ElseIf TypeOf swSegment Is Edge Then
    Dim swEdge As Edge
    Set swEdge = swSegment
    Dim swCurveParamData As CurveParamData
    swCurveParamData = swEdge.GetCurveParams3
    StartPoint = swCurveParamData.StartPoint
    EndPoint = swCurveParamData.EndPoint
  Else
    Exit Function
  GetStartEndPoint = True
  Debug.Print "Start ", StartPoint(0), StartPoint(1), StartPoint(2)
  Debug.Print "End   ", EndPoint(0), EndPoint(1), EndPoint(2)
End Function
