I found on this forum the following macro from and I modified it with my custom properties.
My problem is that, when I have a sub-assembly I am not able to change the component name of the sub-assembly.
As you can see in the following image all the parts, also the sub-assembliy parts, have been renamed (code-revision-description) but the sub-assembly remains with the original file name (code).
Is there a way to modify the macro?
Thanks in advance.
' Macro to Rename Part File (component name) with configuration properties.swp ------------- 07/19/13
'Description: Rename Part File (component name) based on specified configuration properties of the component in current active assembly file.
'Precondition: Any active assembly file with minimum one part file.
'Postconditions: Part Files (component name)are changed to new name based on specified properties.
' Please back up your data before use and USE AT OWN RISK
' This macro is provided as is. No claims, support, refund, safety net, or
' warranties are expressed or implied. By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability. Free distribution
' and use of this code in other free works is welcome. If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header). All other
' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors. Use at your own risk!
' Written by: Deepak Gupta (http://gupta9665.com/)
Option Explicit
Public Enum swUserPreferenceToggle_e
swExtRefUpdateCompNames = 18
End Enum
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim bRet As Boolean
Dim bOldSetting As Boolean
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As String
Dim sPadStr As String
Dim i As Long
Dim swChildModel As SldWorks.ModelDoc2
Dim NewName As String
Dim Descrizione As String
Dim Revisione As String
Dim Codice As String
bOldSetting = swApp.GetUserPreferenceToggle(swExtRefUpdateCompNames)
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, False
For i = 0 To nLevel - 1
sPadStr = sPadStr + " "
Next i
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
Set swChildModel = swChildComp.GetModelDoc
If swChildModel.GetType = swDocPART Then
swChildComp.Select2 False, 0
'Get configuration name
swCompConfig = swChildComp.ReferencedConfiguration
' Get Configuration Properties Values
Codice = swChildModel.CustomInfo2(swCompConfig, "CODICE")
Descrizione = swChildModel.CustomInfo2(swCompConfig, "DESCRIZIONE")
Revisione = swChildModel.CustomInfo2(swCompConfig, "REVISIONE")
NewName = Codice + "-" + Revisione + "-" + Descrizione
swChildComp.Name2 = NewName
Debug.Print swChildComp.Name2
TraverseComponent swChildComp, nLevel + 1
Next i
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, bOldSetting
Set swModel = swApp.ActiveDoc
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
TraverseComponent swRootComp, 1
