5 Replies Latest reply on Jul 1, 2017 2:06 PM by Amen Allah Jlili
    How to open/import CatiaV5 data using vba?
    Michael Pieper
      Good Morning Gentleman,
      I was wondering how to use the available Interconnect functionality to import CATIA V5 data using a simple macro.
      Using the OpenDoc6 method is obviously not doing the needful.
      So I tried to record a macro of manually opening a CATIA V5 element using the file/open dialog within SolidWorks. The process was sucessfull (as expected) but taking a look into the generated macro was only showing the creation of the sldprt but not showing anything regarding the actual method used to open the file in the first step.
      Any advice?
      Thanks in advance and best regards,
      Michael
        • Re: How to open/import CatiaV5 data using vba?
          Cad Admin
          Are you trying to convert part...then insert into an assembly? or inserting native into an assembly.
          Below is a recorded "inserting native into an assembly", which includes some convert & transform code...
          ' C:\Users\XXXXX\AppData\Local\Temp\swx7732\Macro1.swb - macro recorded on 06/29/17
          Dim swApp As Object
          Dim Part As Object
          Dim boolstatus As Boolean
              Set Part = swApp.ActiveDoc
          ' New Document
              Dim swSheetWidth As Double
              swSheetWidth = 0
              Dim swSheetHeight As Double
              swSheetHeight = 0
              Set Part = swApp.NewDocument("D:\Solidworks Custom Paths\Templates\Part.prtdot", 0, swSheetWidth, swSheetHeight)
              Dim swPart As PartDoc
              Set swPart = Part
              swApp.ActivateDoc2 "Part5", False, longstatus
              boolstatus = Part.EditRebuild3()
          ' Insert Component
              Dim AssemblyTitle As String
              AssemblyTitle = Part.GetTitle
              Dim tmpObj As ModelDoc2
              Dim errors As Long
              Set tmpObj = swApp.OpenDoc6("C:\Users\XXXXX\Desktop\mdrawing test\model2.prt.SLDPRT", 1, 32, "", errors, longwarnings)
              Set Part = swApp.ActivateDoc3(AssemblyTitle, True, 0, errors)
              Dim swInsertedComponent As Component2
              Set swInsertedComponent = Part.AddComponent5("C:\Users\XXXXX\Desktop\mdrawing test\model2.prt.SLDPRT", 0, "", False, "", 0.183225696407994, 0.183474767172876, 0.18322569640805)
              swApp.CloseDoc "C:\Users\XXXXX\Desktop\mdrawing test\model2.prt.SLDPRT"
              Dim TransformData() As Double
              ReDim TransformData(0 To 15) As Double
              TransformData(0) = 1
              TransformData(1) = 0
              TransformData(2) = 0
              TransformData(3) = 0
              TransformData(4) = 1
              TransformData(5) = 0
              TransformData(6) = 0
              TransformData(7) = 0
              TransformData(8) = 1
              TransformData(9) = 0
              TransformData(10) = 0
              TransformData(11) = 0
              TransformData(12) = 1
              TransformData(13) = 0
              TransformData(14) = 0
              TransformData(15) = 0
              Dim TransformDataVariant As Variant
              TransformDataVariant = TransformData
              Dim swMathUtil As Object
              Set swMathUtil = swApp.GetMathUtility()
              Dim swTransform As Object
              Set swTransform = swMathUtil.CreateTransform((TransformDataVariant))
              boolstatus = swInsertedComponent.SetTransformAndSolve2(swTransform)
              Dim swcomp As Object
              Set swcomp = Part.SelectionManager.GetSelectedObject6(1, -1)
              boolstatus = swcomp.MakeVirtual2(True)
          FYI this was with a UN NX part...however Catia should be similar enough....
