VBA API: Using EditRebuild3 while Traversing Assembly
Question asked by Cad Admin on Jun 28, 2017
Latest reply on Jul 6, 2017 by Cad Admin
I have a macro that a coworker wrote it worked fine, i went back to it a few days later and it is not completing its task.  Its supposed to traverse through an assembly find all of the customer parts (in this case models with 256666 in the name, then run EditRebuild3.  While it work when he saved it a few days ago, it is failing now.  It traverses fine, fails on the EditRebuild3 on the qualifying models.
Option Explicit
    Dim swApp                     As SldWorks.SldWorks
    Dim swModel                   As SldWorks.ModelDoc2
    Dim swConfigMgr               As SldWorks.ConfigurationManager
    Dim swAssy                    As SldWorks.AssemblyDoc
    Dim swConf                    As SldWorks.Configuration
    Dim swRootComp                As SldWorks.Component2
    Set swModel = swApp.ActiveDoc
    Set swConfigMgr = swModel.ConfigurationManager
    Set swConf = swConfigMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    TraverseComponent swRootComp, 1
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp                  As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim swCompConfig                As SldWorks.Configuration
    Dim i                           As Long
    Dim bRet                        As Boolean
    Dim swCompModel                 As SldWorks.ModelDoc2
    Dim boolstatus                  As Boolean
    Dim Part                        As Object
    Dim PartName                    As String
    Set swCompModel = swComp.GetModelDoc2
    If swCompModel.GetType() = swDocPART Then
    'If swCompModel.GetType = swDocASSEMBLY Then
    Debug.Print "Component: " & swComp.Name2
        bRet = swComp.Select4(True, Nothing, True)
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        TraverseComponent swChildComp, nLevel + 1
        If InStr(swChildComp.Name2, "256666") Then
            'Debug.Print "Component: " & swChildComp.Name2
            Set Part = swCompModel
            PartName = swChildComp.Name2
            boolstatus = Part.Extension.SelectByID2(PartName, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
            boolstatus = Part.EditRebuild3()
        Next i
    swCompModel.ClearSelection2 True
