What is the difference between the ExtensionLineDirection statement and DimensionLineDirection statement.
code is
Private Sub del1()
Dim swApp As SldWorks.SldWorks, swModel As ModelDoc2
Set swModel = swApp.ActiveDoc
Dim SwSelMgr As SelectionMgr
Set SwSelMgr = swModel.SelectionManager
Dim swDispDim As DisplayDimension, swDim As Dimension
Set swDispDim = SwSelMgr.GetSelectedObject5(1)
With swDispDim
Debug.Print .Type2
Set swDim = .GetDimension
End With
Dim vDir, vDir1, Str
Dim MathVect As MathVector, MathVect2 As MathVector
With swDim
Set MathVect = .DimensionLineDirection
vDir = MathVect.ArrayData
Str = "DimensionLineDirection is Direction ("
For ii = 0 To 2
Str = Str & vDir(ii) & ","
Next ii
Str = Left(Str, Len(Str) - 1) & ")"
Debug.Print Str
Set MathVect = .ExtensionLineDirection
vDir1 = MathVect.ArrayData
Str = "ExtensionLineDirection is Direction ("
For ii = 0 To 2
Str = Str & vDir1(ii) & ","
Next ii
Debug.Print Str
Stop
Stop
End With
Stop
2017 SOLIDWORKS API Help - ExtensionLineDirection Property (IDimension) http://help.solidworks.com/2017/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.idimension~extensionlinedirection.html
2017 SOLIDWORKS API Help - DimensionLineDirection Property (IDimension) http://help.solidworks.com/2017/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.idimension~dimensionlinedirection.html
Get Display Dimension Type - API | SOLIDWORKS Forums https://forum.solidworks.com/message/317119#comment-317119
GetAttachedEntities | SOLIDWORKS Forums https://forum.solidworks.com/message/749451#comment-749451
Horizontal or Vertical Dimension? | SOLIDWORKS Forums https://forum.solidworks.com/message/687424
How to move Arrow point of Note (balloon)? | SOLIDWORKS Forums https://forum.solidworks.com/message/757281#comment-757281
How to determine the vertical size, or horizont... | SOLIDWORKS Forums https://forum.solidworks.com/message/721540#comment-721540
