EditDimensionProperties3,use chr(13) result  is error.
Question asked by Yong Ning on Jun 28, 2017
Latest reply on Jun 29, 2017 by Peter Brinkhuis
using the following code to create text below a dimension in a drawing. multiple lines. If anyone can point me to how to add a carriage return to this I would appreciate it!
Follow code, chr(13) result  is error.
Artificial press enter, dimensioning results correctly.
Private Sub dell()
   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
       Set SwApp = Application.SldWorks
       Set SwModel = SwApp.ActiveDoc
   Dim SwSelMgr As SelectionMgr, Str
       Set SwSelMgr = SwModel.SelectionManager
   Dim SwDispDim As DisplayDimension
       Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
       Str = "<DIM>" & Chr(13) & "(0,0,1)" & Chr(13)
       SwModel.EditDimensionProperties3 0, 0, 0, "", "", 1, 9, 2, 1, 11, 11, "", Str, 1, "", "", True, swAllConfiguration, ""
Dim SwDim As Dimension
    SwDim.Value
Private Sub del2()
        SwDispDim.SetText SwConst.swDimensionTextParts_e.swDimensionTextAll, Str
How to enter multiline text below dimension via... | SOLIDWORKS Forums  https://forum.solidworks.com/thread/201334
Function GetOrientation(swDisplayDimension As DisplayDimension) As String
    Dim SwDim As SldWorks.Dimension
    Set SwDim = swDisplayDimension.GetDimension '2(0)
    Dim swMathVec As SldWorks.MathVector
    Dim vDir As Variant
    GetOrientation = ""
    Set swMathVec = SwDim.DimensionLineDirection
    vDir = swMathVec.ArrayData
    If IsCollinear(vDir(0), 1) And IsCollinear(vDir(1), 0) Then
        GetOrientation = "HOR"
    ElseIf IsCollinear(vDir(1), 1) And IsCollinear(vDir(0), 0) Then
        GetOrientation = "VER"
End Function
Function IsCollinear(val As Variant, vector As Double) As Boolean
    Const TOL = 0.00000001
    IsCollinear = Abs(Abs(val) - Abs(vector)) < TOL
End Function
Function RefPtArr(SwModel As ModelDoc2, SwMathUtil As MathUtility, SwView As View, SwDispDim As DisplayDimension)
   Dim SwXForm As MathTransform
       Set SwXForm = SwView.ModelToViewTransform
   Dim SwAnn As Annotation, SwAnn1 As Annotation
   Dim Ss, oScale, ii, Str
   Dim MathPt As MathPoint
   Dim SwNote As Note
       With SwDispDim
           Set SwDim = .GetDimension
           'Debug.Print SwDim.FullName
           Set SwAnn = .GetAnnotation
           Ss = SwDim.ReferencePoints
           oScale = 1
           For ii = 0 To 2
               Set MathPt = Ss(ii)
               Set MathPt = MathPt.MultiplyTransform(SwXForm)
               With MathPt
                        Debug.Print "   xy(" & ii & "," & 0 & ")=" & Round(.ArrayData(0), 6) & ":",
                        Debug.Print "   xy(" & ii & "," & 1 & ")=" & Round(.ArrayData(1), 6)
                        tmp = SwModel.Extension.SelectByID2("", "VERTEX", .ArrayData(0), .ArrayData(1), .ArrayData(2), False, 0, Nothing, 0)
                        Str = GetOrientation(SwDispDim) & "-" & SwDim.Name & "-" & ii
                        Str = Str & vbCr & " (" & Round(.ArrayData(0), 4) & "," & Round(.ArrayData(1), 4) & ",0)"
               End With
               Set SwNote = SwModel.InsertNote(Str)
               Set SwAnn1 = SwNote.GetAnnotation
           Next ii
       End With
   Dim MathVext As MathVector, Pt(2) As Double
       Set MathVect = SwDim.DimensionLineDirection
       vDir = MathVect.ArrayData
       'Str = "<STACK><DIM><OVER>DimensionLineDirection is Direction ("               ''
       Str = SwDispDim.GetText(swDimensionTextAll)
       'Stop
       'Str = SwDispDim.GetText(swDimensionTextAll) & vbCrLf & "("
       'Str = vbCrLf & "("
       'Str = "<DIM>" & vbCrLf & "("                ''
       'Str = vbCrLf & "("
       Str = "("
       For jj = 0 To 2
            Str = Str & Round(vDir(jj), 5) & ","
       Next jj               ''
       Str = Left(Str, Len(Str) - 1) & ")" '& vbCrLf
       Ss = SwAnn.GetPosition
       SwAnn.Select True
       'SwDispDim.SetText SwConst.swDimensionTextParts_e.swDimensionTextAll, Str
       SwModel.EditDimensionProperties2 0, 0, 0, "", "", 1, 9, 2, 1, 11, 11, "", "", 1, "", Str, 1
       'SwDispDim.SetText swDimensionTextCalloutBelow, Str
       SwModel.GraphicsRedraw2
       'SwDispDim.SetText swDimensionTextCalloutAbove, Str
       'For ii = 0 To 2
           'Pt(ii) = Ss(ii)
       'Next ii
       'tmp = SwModel.Extension.SelectByID2("", "DRAWINGVIEW", Ss(0), Ss(1), 0, False, 0, Nothing, 0)
       'Set SwNote = SwModel.InsertNote(Str)
End Function
Private Sub del20170625()
    Dim SwMathUtil As MathUtility
         Set SwMathUtil = SwApp.GetMathUtility
    Dim SwDraw As DrawingDoc
         Set SwDraw = SwModel
    Dim SwView As View
         Set SwView = SwDraw.GetFirstView
    Dim SkSketch As Sketch, SkPtArr
         Set SkSketch = SwView.GetSketch
         SkPtArr = SkSketch.GetSketchPoints
         If Not IsEmpty(SkPtArr) Then
            For ii = 0 To UBound(SkPtArr)
                Set SkPt = SkPtArr(ii)
                SkPt.Select True
            Next ii
            SwModel.EditDelete
    Dim SwNote As Note, SwAnn As Annotation, Anns
         Set SwView = SwView.GetNextView
         Do While Not SwView Is Nothing
             SwModel.ClearSelection2 True
             Set SwNote = SwView.GetFirstNote
             Do While Not SwNote Is Nothing
                'Debug.Print SwNote.GetText
                Set SwAnn = SwNote.GetAnnotation
                SwAnn.Select True
                Set SwNote = SwNote.GetNext
             Loop
             SwModel.EditDelete
             Set SwDispDim = SwView.GetFirstDisplayDimension
             Do While Not SwDispDim Is Nothing
                  With SwDispDim
                       If .Type2 = 2 Or .Type2 = 11 Or .Type2 = 12 Then
                           Debug.Print "'******** Êý×é" & SwDispDim.GetDimension.Name
                           Arr = RefPtArr(SwModel, SwMathUtil, SwView, SwDispDim)
                  End With
                  Set SwDispDim = SwDispDim.GetNext
             Loop
         Loop
