I wanted to take the CSWP exam so I did the sample question. I made the part and everything seems correct to me however I couldn't get the correct answers. I even redo it a few times and tried something different each time trying to find what I did wrong but still didn't work.. I noticed that even when I got the answer right for question 1, but when I modified the equations for the next question, the answer was wrong. I tried changing the equations back for question 1, the answer is different from the first time... please helpp!!!!!
I have just had a quick look through your file set and it appears to be caused by the fact you have multiple solid bodies within the model. To correct the issue you will need to edit the boss extrude 5 feature and select the tick box to merge results. If you then edit the global variables to the values needed for question 2 this will in turn give you the correct answer. I hope this helps. thanks.
