Help selecting Edges of a contour
Question asked by Prashant Mohan on Jun 26, 2017
Latest reply on Jan 13, 2018 by Prashant Mohan
I have code that gets the active sketch. It then gets all the contours of the sketch and selects one contour at a time. After that it gets all edges of each contour and loops through the edges and selects them. The sketch itself consists of bunch of rectangles.
Issue is when i select the contour it highlights the contour (of that rectangle) but when i select an edge it does not do the same neither does it give me any error. Any ideas or suggestion will be appreciated.
Dim vSkContours As Variant
Dim SelMgr As SldWorks.SelectionMgr
Dim mySelectData As SldWorks.SelectData
Dim swSelData As SldWorks.SelectData
Dim mySketch As SldWorks.Sketch
Dim skContour As SketchContour
Dim vEdges As Variant
Dim myEdge As SldWorks.Edge
Dim swEntity3 As SldWorks.Entity
Dim len1 As Integer, len2 As Integer, lenRe As Integer, counter As Integer
Dim feature As feature
Set SelMgr = Curr_Part.SelectionManager
Set mySelectData = SelMgr.CreateSelectData
Set mySketch = Curr_Part.GetActiveSketch2()
vSkContours = mySketch.GetSketchContours()
  If Not mySketch Is Nothing Then
        contourCount = UBound(vSkContours) - LBound(vSkContours) + 1
        For i = LBound(vSkContours) To UBound(vSkContours)
            Set skContour = vSkContours(i)
             bRet = skContour.Select2(False, mySelectData)
            vEdges = skContour.GetEdges()
            len1 = 0
            If IsEmpty(vEdges) Then
                Debug.Print "    No edges."
            Else
               len1 = UBound(vEdges)
             For k = LBound(vEdges) To UBound(vEdges)
                Set myEdge = vEdges(k)
                If Not myEdge Is Nothing Then
                    Debug.Print "    Edge " & k & ": "
                    Set swEntity3 = myEdge
                    bRet = swEntity3.Select4(False, mySelectData)
            Next k
        Next i
Regards,
Prashant Mohan
