In my weldment cut list it does not list is description when I used my my configured weldment but it is listed in the table.
I tried to figure that out, but nothing I click on seems to bring up a window to get to that information.
Hover over your BOM to highlight it, then click on the Letter at the top of the column (A in the screenshot). That will bring up the bar shown. Click on the "Column Property" icon. That will let you select the property you want the column linked to.
My reading comprehension must not be all it should today. Sorry about that. I gave you information for linking BOM columns to properties. You're right, it works different for cut lists (why they work different is one of the great mysteries of life). In that case I'm pretty sure that your column in your design table isn't properly linked. See the response above from Rob Edwards.
Are you sure the column in the cut list is properly linked to the Description property?
