DSDaniel Sailer25/06/2017
Hi SolidWorks Macro specialists,
I have a simple macro to export drawings to DXF.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
If (swApp.ActiveDoc.GetPathName = "") Then          'Check if file is saved
    MsgBox ("First save the drawing!")
    Exit Sub
saveFileName = Left(swApp.ActiveDoc.GetPathName, Len(swApp.ActiveDoc.GetPathName) - 7) + ".dxf" ' Save as DXF
longstatus = Part.SaveAs2(saveFileName, 0, 1, 1)
Now the goal is to export the drawing without saving it before. How can I get the name and Path of the parent part? This is needed for, I think it is called like "flat pattern ..." in English. In this case there is no need to save the drawing.
Hopefully you understand my explanation.
Thank you very much!
Daniel
