3 Replies Latest reply on Jun 25, 2017 2:42 PM by Deepak Gupta
    Mass Properties
    Eddie Capps
      I have a simple macro that overrides the Mass Properties of a part. I use it to assign a weight to a purchased part. (Example: A Bearing)
      The macro will open the Mass Properties window. It goes to the Override Mass Properties page, prompt you for the new mass of the part. Then closes
      that page. Here's my problem. The Mass Properties window stays open. Any ideas??
      Thanks in advanced for anyone's help.
        • Re: Mass Properties
          Deepak Gupta
          Why are you opening that window? You can set an input box to get the value and apply the factor for unit conversion based on the model unit.
          Option Explicit
          Dim swApp       As SldWorks.SldWorks
          Dim swModel     As SldWorks.ModelDoc2
          Dim MyMassProp  As SldWorks.MassProperty
              Set swModel = swApp.ActiveDoc
              Set MyMassProp = swModel.Extension.CreateMassProperty
              MyMassProp.OverrideMass = True
              'Change Weight Value Here. Use conversion factor as needed.
              MyMassProp.SetOverrideMassValue 10, swThisConfiguration, Nothing
              Eddie Capps
              Thanks for the advice. I'm new to writing macros. So I always start by recording my steps. Then make some changes. That's how I got to opening this window. But I'm learning. Again, thanks for your help.
                  Deepak Gupta
                  Glad to know that you're trying and learning.. Keep it up
