I can not create anything in solidworks electrical.
Projects, parts, macros, among others
Log EwADLLOG.txt
[25/06/2017 18:31:42] MESSAGE: Invalid object name 'tew_cususerdata'. (Number : -2147217865) PARAM: SELECT * FROM tew_cususerdata WHERE 0 = 1; FUNCTION: TrADLRecordsetADO::openSQL FILE: TrADLRecordsetADO.cpp LINE: 170
[25/06/2017 18:31:42] MESSAGE: SQL error or missing database PARAM: SELECT FROM tew_cususerdata WHERE EXISTS(SELECT * FROM tew_cablereference WHERE car_uid=cus_car_uid AND ( car_update<>3 ) );
near "FROM": syntax error FUNCTION: TrADLRecordsetSQLite::executeAndLoad FILE: TrADLRecordsetSQLite.cpp LINE: 620
[25/06/2017 18:32:10] MESSAGE: Invalid object name 'tew_user'. (Number : -2147217865) PARAM: SELECT usr_id ,usr_gro_id ,usr_username ,usr_pwd ,usr_firstname ,usr_lastname ,usr_initial ,usr_signblock ,usr_creationdate ,usr_modificationdate ,usr_datatype FROM tew_user ; FUNCTION: TrADLRecordsetADO::openSQL FILE: TrADLRecordsetADO.cpp LINE: 170
[25/06/2017 18:32:10] MESSAGE: Invalid object name 'tew_project'. (Number : -2147217865) PARAM: SELECT pro_id,pro_type,pro_indefaultpath,pro_name,pro_path,pro_pdmvault,pro_pdmuser,pro_directory,pro_customername,pro_custaddress1,pro_custaddress2,pro_custaddress3,pro_drawingofficename,pro_doaddress1,pro_doaddress2,pro_doaddress3,pro_contractnb,pro_version,pro_nod_clauid,pro_creationdate ,pro_modificationdate ,pro_datatype ,pro_lib_name ,pro_macrotype,pro_snapshot ,use_objectid ,use_objectno ,use_data0 ,use_data1 ,use_data2 ,use_data3 ,use_data4 ,use_data5 ,use_data6 ,use_data7 ,use_data8 ,use_data9 ,use_data10 ,use_data11 ,use_data12 ,use_data13 ,use_data14 ,use_data15 ,use_data16 ,use_data17 ,use_data18 ,use_data19 FROM tew_project LEFT JOIN tew_userdata ON tew_project.pro_id = tew_userdata.use_objectid ; FUNCTION: TrADLRecordsetADO::openSQL FILE: TrADLRecordsetADO.cpp LINE: 170
[25/06/2017 18:32:17] MESSAGE: Invalid object name 'tew_objectid'. (Number : -2147217865) PARAM: SELECT obj_objectid FROM tew_objectid ORDER BY obj_objectid ; FUNCTION: TrADLRecordsetADO::openSQL FILE: TrADLRecordsetADO.cpp LINE: 170
[25/06/2017 18:32:17] MESSAGE: Operação não permitida quando o objeto está fechado. (HRESULT: 0x800a0e78) PARAM: FUNCTION: TrADLRecordsetADO::update FILE: TrADLRecordsetADO.cpp LINE: 943
[25/06/2017 18:32:20] MESSAGE: Invalid object name 'tew_project'. (Number : -2147217865) PARAM: INSERT INTO tew_project (pro_id,pro_type,pro_indefaultpath,pro_name,pro_path,pro_pdmvault,pro_pdmuser,pro_directory,pro_customername,pro_custaddress1,pro_custaddress2,pro_custaddress3,pro_drawingofficename,pro_doaddress1,pro_doaddress2,pro_doaddress3,pro_contractnb,pro_version,pro_nod_clauid,pro_creationdate ,pro_modificationdate ,pro_datatype ,pro_lib_name ,pro_macrotype,pro_snapshot ) VALUES (-1,0,1,N'JIS_-1' ,N'' ,N'' ,N'' ,N'-1' ,N'' ,N'' ,N'' ,N'' ,N'' ,N'' ,N'' ,N'' ,N'' ,235 ,-2 ,N'20170625 18:32:18 ' ,N'20170625 18:32:18 ' ,2,N'' ,0,0) FUNCTION: TrADLConnectionADO::execute FILE: TrADLConnectionADO.cpp LINE: 182
[25/06/2017 18:32:20] MESSAGE: Invalid object name 'tew_userdata'. (Number : -2147217865) PARAM: DELETE FROM tew_userdata WHERE use_objectid = -1 FUNCTION: TrADLConnectionADO::execute FILE: TrADLConnectionADO.cpp LINE: 182
[25/06/2017 18:32:20] MESSAGE: Invalid object name 'tew_translatedtext'. (Number : -2147217865) PARAM: DELETE FROM tew_translatedtext WHERE tra_objectid = -1 FUNCTION: TrADLConnectionADO::execute FILE: TrADLConnectionADO.cpp LINE: 182
[25/06/2017 18:32:20] MESSAGE: Invalid object name 'tew_project'. (Number : -2147217865) PARAM: DELETE FROM tew_project WHERE pro_id = -1 FUNCTION: TrADLConnectionADO::execute FILE: TrADLConnectionADO.cpp LINE: 182
I would suggest installing the server component as well as a client on the server as the first thing. Then you can get the server up an running knowing that none of your issues are network related. Once it's running then try to connect from other clients on the network.
