i am trying to simulate a water cooled element (see attached sketch)
Solid 1 is a heat source, Solid 2 is made of a different material and the connection between these 2 is not ideal. Water is flowing (direction: through the paper) and the air is still. So it's the water that cools the whole system. the simulation itself is going good.
But i would like to add a thermal contact resistance between Solid1 and Solid 2. But i can't find how to do this.
Is it possible that i have to swap to a different kind of simulation to do this?
Hopefully someone can help because i have been searching for a solution for a while now.
Thanks in advance.
Theo,
You got gotta add the comand, since it not by default in your simulation tree. To do this you start by right mouse click the name of the project (Project(1) in this case) in the simulation tree and selecting Customize Tree.
Then look for Contact Resistances
When you select the option, now its gonna appear on your simulation tree.
Then you gotta apply it to the correct faces
Regards,
GF
