Good morning,
Here is what I am trying to do:
1. Have a library feature be a bolt circle with the holes already in place.
2. Drag the library feature bolt circle (using the center point as the origin) from the design library to a specific point on a face.
3. have the holes automatically add to the block on that face using that center point.
I use this currently for a specific custom hole that I drag and drop. (works great)
I am just hoping I can do the same thing, in one motion, to drag and drop a similar feature, but have 8 holes on a bolt circle added. (4 1/4"-20 tap, and 4 1/4" reams)
Thank you
Mark
Mark,
This is easy to do.
It has been a couple of years since I created our standard bolt patterns for square locators, but if I remember correctly since you have already created 1 library feature this is no more difficult. Instead of choosing one hole hold ctrl and select all holes and sketches in your model to save as a library feature. You can then drag and drop on faces. You may need to select edit sketch function when inserting to define the origin, but other than that what you are asking is possible.
