I can't insert any goals in Flow simulation 2009, because the
entire parameter list is invisible. When I hover over different
areas on the blank list, the arrow tells me what test I should be
able to see, but I can't click on anything. These seems to be a
bug. The error seems to be the same as Danny Sawchuck's post on
12/19. Is there a fix for this?
....there is indeed a bug with windows VISTA in 2009.
A workaround is to use the "create associated goals" option in a boundary condition.
You need to define first what are automatic defined goals in Tools / otions / third party /.
