3 Replies Latest reply on Jun 22, 2017 1:38 PM by Deepak Gupta
    Save IGES file from referenced Part in Drawing
    Jacob Fackelman
      Hello All,
      My end result is to have the macro save the igs file and make a pdf of the drawing, and run it thru the task scheduler for a list of drawings, does that sound doable?
      I've modified this Macro from one Deepak Gupta did awhile back basically my changes have been to save it as a .igs file instead of .step. For whatever reason simply changing the file extension from .step to .igs breaks something and the macro will not save the referenced part file. Ive looked at similar codes and to my best efforts i cant find the problem. The pdf section works great its just some problem with saving igs files. With the code as it stands by changing the extension to .step or .x_t the code works perfectly however my company is dead set on using .igs files.
      Thanks in advance, this is my first posting to the forum and my first attempt at a macro.
