Hello SolidWorks gurus,
I am trying to make changes to an object that I mirrored on a plane. I want to change the angle of one of the exit holes from the original copy of the object but every time I try to edit the feature it sends me to editing the mirroring itself. Is there a way to edit the shape/elements of an object that is only a mirrored copy of the original form? Thanks!
Hi Sonny,
From the mirror component command if you save it out as another file and use the highlighted option from below you will be able to work on the mirrored part independantly
