I have made some custom graphics to use in my .smg. At one point I needed to change the graphics somewhat and re-saved over the old one. The file path is still the same. Sometimes (like one out of ten) I can get the images (not 3D models) to update to the updated image (jpg, bmp, etc.) if I totally shut Composer down and restart the program. However, this is very inconsistent and only some of the images update. I have even went so far as to restart my computer - same result. I have had to save the image file with a new name and then link that to get the graphic to update.
Any suggestions to get the images to update without jumping through hoops?
Thanks in advance!
external images will be imported into the smg file!
So ,if you use a updated image file, change the name _v1, _v2, ...
afterwards import them again
Other way: save the smg file. Then change .smg to .zip. Open the ZIP and you will find the .jpg files (same name) inside this ZIP. Exchange them and close the ZIP. Afterwards change back zu .smg!
