Hi.
I am new to this so I am probably missing something obvious. I have the following part to which I added connection points and specified the stub diameter as 1.5mm and length as 10mm. The stub does not appear when the green tick is clicked also, when I view the part in the assembly view the actual connection point (with arrow) or the stub are visible and hence I cannot add cable to it. Should they both appear in the assembly view and is there a way to enable it.
Thanks.
M.
Mark,
Stubs will only show up when you add a cable route to an assembly & only then when you right click on a connection point & select add to route.
