I'm using the eModelView activeX control (eDrawings 2016 SP5 version) on a Visual Studio 2010 vb.net winforms application (64bits and target framework=.NET 4.0).
I'm able to load any file on the control, but after that what I want to do is to export the content to a PDF file using the PDFCreator printer.
I'm using the Print5 method. If I set the first parameter (ShowDialog) to TRUE, there is no problem, but if I set to FALSE it doesn´t work (it generates a bad format PDF file or just triggers the OnFailedPrintingDocument event).
Does anyone know how to solve it?
Thanks in advance.
More info...
This is the code I'm using:
If Visor_SW.SheetWidth < Visor_SW.SheetHeight Then
Visor_SW.SetPageSetupOptions(EModelView.EMVPrintOrientation.ePortrait, Printing.PaperKind.A4, 1, 1, 1, Printing.PaperSourceKind.AutomaticFeed, "PDFCreator", 0, 0, 0, 0)
Else
Visor_SW.SetPageSetupOptions(EModelView.EMVPrintOrientation.eLandscape, Printing.PaperKind.A4, 1, 1, 1, Printing.PaperSourceKind.AutomaticFeed, "PDFCreator", 0, 0, 0, 0)
Visor_SW.Print5(False, Visor_SW.FileName, True, True, True, EModelView.EMVPrintType.eScaleToFit, 1, 0, 0, True, 1, 1, "")
It also fails using:
Visor_SW.Print5(False, Visor_SW.FileName, True, True, True, EModelView.EMVPrintType.eScaleToFit, 1, 0, 0, True, 1, 1, output_file)
Thanks a lot
