Component Sketch Pattern Warning: Pattern Instance Overlapping Seed
Question asked by Rob Edwards on Jun 19, 2017
Latest reply on Jun 19, 2017 by Dan Pihlaja
Good Morning this fine Monday
I'm not sure I've noticed this before.  I have a sketch of points created in a part, which I then use to pattern some components at the assembly level.  I inserted my seed component using one of the points, but the pattern adds another component on top of the seed.  In Instances to Skip I am not able to deselect the 'guility' pattern instance (No Pink Dot - Lower Left).  I have made my seed component an envelope so it will be excluded from the BOM, but this doesn't remove the warning.  It is only a warning and no big deal, but how would I go about doing this correctly?  Do I have to add my seed component somewhere unrelated to the sketch points? (removes warning but seems illogical) or construct a sketch of points without the seed position (difficult and unnecessary)
Thanks for reading,, Im using SW15
