Hi all,
So, I have been 3D scanning some objects and processing them with either meshmixer or meshlab.
However, I use SoldiWorks for all 3D needs.
Here's the issue that'd like to fix, everytime I try to open a file that came from a 3D scan in SolidWorks, I end up with many polygons like attachment 1.0
Then a friend of mine offered to help, he used 3DS Max, and he was able to reduce the and clean up poly count without distorting the surface.
That was the 1st successful step! yayy See attachement 2.0
BTW, when I tried to reduce the poly count in = Meshmixer and meshlab, I wasn't successful since it distorted the curvature and shape of object.
Still the issue is the polygons or mesh elements. Since I would like to edit and design around scanned objects, I need all surfaces to be continuous.
Meaning, instead of having 1000 triangles or squares representing the surface, I want one solid continuous surface.
I uploaded a SolisWorks part file as well here. Attachment 3.0
Summary:
- 3D Scanned mesh file
- Saved in a format that SodidWorks (STL) reads using MeshLab and MeshMixer
- Opened in SolidWorks as solid (from options we could chose solid or surface, we need solid)
- End up with a solid part with many high poly count on every surface (surfaces are segmented)
- We need a solution to replace all polygons with one continous surface with no elements of ploygons.
Any suggestions? all help is very much appreciated.
Many thanks,
Omar
Message was edited by: Omar Title Editied
Do you have SolidWorks Premium or Professional? The Scan to 3D add in might help to convert large meshes to SolidWorks surfaces which you could then use as a reference for modeling new geometry. Without Scan to 3D, 15,000 or so triangles is the limit for Solid Body import.
Significantly decimating the mesh AND preserving detail you need as a reference using the applications you mentioned is not possible unless your objects are very simple, like your example.
I think Power Surfacing RE might help. I have just leaned it has some new features for reverse engineering from scans. I'm going to give the trial a look myself.
