I'm trying to install the Student/Maker version and I get the following error:
The posts I've found related to this error all suggest installing Microsoft Visual C++ Redistributable 2012, which I have done, and even repaired existing installations with no luck. I'm open to suggestions. I have installation logs but no where to send them to.
Bill
Hi Bill,
I have seen this issue before and it was fixed by performing a system restore (failing that repairing your windows installation itself should also work as a more thorough fix). I would recommend you make a back up of your files and play around with your windows restore and repair options.
