You would probably have to ask them if they have them available. They seem to have the parts available as downloads so you may have to download them all individually and save them in a folder and then add that to the design library. That way you can drag and drop them if.
That's the way I work right now. However, there is a slow and somewhat complicated approach. It is necessary to select the part to record it in STEP or Solid Works and switch it. I wonder if there is a shorter and simpler way.
Chris
