JSJonathan Sterling14/06/2017
Hi all,
I have searched the forums here and external to this site trying to find any examples or discussions about the above topic to no avail.
First, what I am trying to do is create a macro (vba) that will open a specifically named document we place in our SW files in the Design Binder.
Second, the two avenues I went down was first to try doing a record to find what SW suggested which returns the following:
     Dim swApp As Object
     Dim Part As Object
     Dim boolstatus As Boolean
          Set Part = swApp.ActiveDoc
          boolstatus = Part.Extension.SelectByID2("Design Journal.doc", "JOURNAL", 0, 0, 0, False, 0, Nothing, 0)
This unfortunately doesn't work at selecting the file, that's when I began digging leading to the second code I was able to piece together based on the runcommand:
     Dim swModExt As SldWorks.ModelDocExtension
     'Dim swComm As swCommand_e
     'Dim pmpTitle As String
     'Dim commandID As Long
          boolstatus = False
          Set swModel = swApp.ActiveDoc
          Set swModExt = swModel.Extension
          boolstatus = swModExt.RunCommand(swCommands_Activate_Doc_Or_Journal, "")
This will open the file, but only if you select it in the feature tree first. So now I am back to square one of how to select the file in the feature tree. Any help or insight would be greatly appreciated.
