I have a part that has global variables in it's equations that then drive multiple dimensions. Can I link those variables to a design table directly, or do I need to drive each dimension with a separate column in the design table and destory the global variable? Maybe I can drive linked dimension values directly?
Or as a third option, drive the part properties that then drive the global variables?
Hi Steven
Not sure about linked values, you'll have to experiment, but global vars and properties easy with a DT
