I have various sketch entities & geometry that help define my sheet format etc. built into my drawing template. This geometry is on a layer that is always kept hidden except when being modified. When I publish my *.slddrw file as an eDrawing some of this geometry (shown in pink below) is shown in the eDrawing. Does anyone know how to prevent this?
- I have tried toggling the visibility of the layer in my slddrw document and re-publishing it as an eDrawing to no avail.
- I have tried turning the layer off in the published eDrawing and saving it in that state but when the eDrawing is reopened the layer is shown again.
Best,
James
James, the one thing I would say I've noticed is that your screen shot shows the layer is hidden which is not the same as turning off the print selection. If you un-hide the layer in question and turn the print toggle off you should get the same message I've posted. IE: "Will not print" when you hover over it. I'd give it a shot just to cross those T's and dot those I's as it were ...
Good luck with it ...
