Hello all,
I'm currently having an issue where I'm opening older part drawings in SW 2017 and basic dimensions are being added to hole dimensions I don't want to be basic. I can change these manually and save the file but when I reopen the file the basic dimensions are back.
I've attached a snippet of the unwanted basic dimensions.
David Koper - Go to Tools ->Options, and click on the "Document Properties" tab. click on "Dimensions" and then on the "Tolerance" button. You can control your dimension type by selecting your choice in the "Tolerance Type" drop down. I hope that helps.
