DTDarius Teichroew14/06/2017
This is probably easy for those of you who are fluent in APIs and VB, but I am stuck trying to get a macro to run at a workflow state. In short, I have this macro that creates a CODE128 barcode image and places it on my drawing. This works fine. However, what I want is for it to auto-generate when it is opened and saved IF it is in a certain workflow state. Below is my code currently, and I've highlighted in red the part that I'm stuck on. I'm not sure if the IF THEN is written correctly, but for some reason, I can't get the "workflowState = aFile.CurrentState" to work correctly. It says "Object variable or With block variable not set".
Any help would be appreciated!
  pic_name = "barcode1" ' The name of a sketch picture on the drawing.
  pic_path = TempPath() & "barcode.emf" ' The path to store the temporary barcode picture on a disk.
  Dim swCustProp As CustomPropertyManager
  Dim mde As ModelDocExtension
  Dim doc As ModelDoc2
  Set doc = swApp.ActiveDoc  ' We will place the barcode into the currently active drawing.
  Set mde = doc.Extension
  Set swCustProp = mde.CustomPropertyManager("")
Dim aFile As IEdmFile5
  Dim workflowState As IEdmState5
  If workflowState = "MODIFIED STANDARD - IN CE" Then
  doc.SelectByName 0, pic_name  ' If we already have a barcode picture on the drawing, let's delete it.
  doc.EditDelete
  Dim ss As StrokeScribeClass  ' The barcode generator object.
  Set ss = CreateObject("STROKESCRIBE.StrokeScribeClass.1")
  Dim bool As Boolean
  Dim val As String
  Dim OrderNumber As String
  Dim resolved As Boolean
  bool = swCustProp.Get5("OrderNumber", False, val, OrderNumber, resolved)
  ss.Alphabet = CODE128B  ' We want to create a Code128 barcode.
  ss.Text = OrderNumber  ' A text to be encoded in the barcode.
  ss.TextBelow = " "
  rc = ss.SavePicture(pic_path, EMF, 50, 50)  ' This will store a 50x50mm barcode picture in a temporary file.
  If rc > 0 Then  ' In a case of error, this displays the error description message.
    MsgBox ss.ErrorDescription
    Exit Sub
  doc.EditSketch
  Dim SkPicture As SketchPicture   ' This loads the picture from the temporary file.
  Set SkPicture = doc.SketchManager.InsertSketchPicture(pic_path)
  SkPicture.SetSize 0.05, 0.035, True  ' Specifying barcode's position and size.
  SkPicture.SetOrigin 0.185, 0.011
  Dim feat As Feature  ' Let's change the name of the barcode object. This allows fo find and delete an old picture if we
  Set feat = SkPicture.GetFeature()                        ' need to update the barcode.
  feat.Name = pic_name
  doc.EditSheet
  Kill pic_path  ' We don't need the temporary picture file anymore.
