I want to have different thickness of walls. Is it possible get this by Multi-thickness Setting in sell tool?
Why is Multi-thickness Setting not explained in the help file?
Same result. Merge would be my first option when building a part I want a a single feature. But I didn't dig into the model, I just saw 2 bodies so I used the combine feature.
Sometimes you want to manipulate part of a body without affecting the rest, so keeping it separate, or splitting it then combining them later is easier.
Hi Maha,
the parameters specifies the thickness and the faces to be removed. The multi-thickness settings allows you to select faces you wish to remain, but have a different thickness. You will need to combine your 2 bodies before this will work.
