Callout generated using API does not point to selected entity
Question asked by Tim Hattrell on Jun 13, 2017
I have a small routine, part of a larger macro. The intent of the routine is to mark an entity with a call out on the screen. When the callout is displayed, it doesn't point to the selected entity. Do I have to specify the coordinates of the callout leader? If yes, what is the best way to get the relevant coordinates for an entity, ie an edge, vertex or surface?
Private Sub selectEntityAndAddCallout(swEntity As SldWorks.Entity, ByVal sCalloutText As String)
        Dim swSelData As SldWorks.SelectData
        Dim swCallout As SldWorks.Callout
        Dim callH As New SwCalloutHandlerClass
        Dim boolstatus As Boolean
        Set swModel = <code deleted>
        Set swSelData = swSelMgr.CreateSelectData
        'Select entity
        Call swModel.ClearSelection2(True)
        boolstatus = swEntity.Select4(False, swSelData)
        'Display callout
        Set swCallout = swSelMgr.CreateCallout2(1, callH)
        boolstatus = swSelMgr.SetCallout(1, swCallout) 'TODO: need to make callout point to selected entity.
        swCallout.Label2(0) = sCalloutText
        swCallout.Value(0) = ""
        swCallout.MultipleLeaders = False
        swCallout.ValueInactive(0) = True
