I am trying to use this feature but I can't figure out what is wrong. If I select the feature and then select any line it creates a circle that is tangent to the origin.
Can someone help me ?
this is what happens:
[img]http://i.imgur.com/UyVTQ94.jpg[/img]
I am trying to do a circular pattern on that spring. Do I have any other options ?
I'm not sure what you are attempting to do from your screenshot. Normally this would be done in the part mode. I am assuming you want the origin of circular pattern in the center of a Circle.. Is that correct?.. If so select the center point of the circle. Hover the mouse over the center until it highlights.
Edit:.. this was done in the drawing.
I think I'm beginning to understand better.. Perhaps.
