I have an assembly where - for demonstration purposes - I'd like the top half of the assembly to sort of fade away (not dynamically - just to have portions faded). I've mocked some images of the effect below on a part (but really I'd like this for an entire assembly)
Here the part fades away to a line drawing
And here it fades to an outline then to nothing.
I'm not after an animation, just some display state that puts focus on a certain portion of the model/assembly, but hints at the rest of it being present. And ideally it will fade completely as in the second image (for reasons I could explain in more detail, as it may help direct out-of-the-box solutions, if the people reading this can fully grasp my design intent)
So far the closest tool I've found is "Transparent Section Bodies" in the Cross section view,
which is fairly close but 1) does not transition gradually & 2) Does not fade completely.
Any improved suggestions?
Hi Bob,
to my knowledge there is no out of the box function in SW to give you the output you're after. You could invest in Composer if you plan on doing this sort of thing a lot, it appears to do what you're after SOLIDWORKS Composer.
Or you can Photoshop it.
EDIT:
I wouldn't be surprised if that image they use on that website to sell composer is actually doctored elsewhere.
