Equation errors every time I open the assembly file
Question asked by Jorge Bento on Jun 13, 2017
Latest reply on Feb 19, 2020 by Domagoj Brlosic
Hello Everyone,
I have an assembly with equations that change part dimensions inside sub-assemblies.
Everything is working as it should when I save the file.
The problem that I’m getting is that every time I open the assembly I get an error on the equations folder that will only go away when I manually open every dimension that is being defined by the equation. All  I have to do is literally open the dimension and save dimension.
The error says: “The equation could not be evaluated because of deleted/invalid dimensions”, which is definitely not true.
I can’t figure out why this is happening, since apparently everything is correct.
I have automatic rebuild and automatic solve order options turned on and every component is set to resolved when I open my assembly
I’m using SW 2016 SP 5.0.
Does anybody else have a similar problem?
Am I doing something wrong here?
Thanks.
