Different Configuration for Each Instance of Pattern
Question asked by Dan Colvin on Jun 12, 2017
Latest reply on Jun 12, 2017 by Dan Colvin
I am attempting to add a set of parts to an assembly, and I'm having trouble finding an efficient solution.  The parts are evenly spaced in a straight line, but each part needs to be slightly longer than the previous.  I can easily make a configuration for each length using a design table, but adding these to the assembly individually is impractical.  Ideally, I could use a linear pattern and have the parts advance to the next configuration with each instance of the pattern.  However, this does not seem to be possible.  Is there any way to accomplish this task without having to manually add the parts or change the configuration of each instance?
Thank you very much.
