8 Replies Latest reply on Jun 19, 2017 12:30 PM by Amen Allah Jlili
    Api issue
    Luigi Piron
      Hy guys, i nave to take a measure by API
      When i preselect the enttity all is ok
      The 1 entity is a Plane
      The 2nd is a coordinate system
      If i create measure it give me an error
      The reason is that it doesn t take the origin of the coordinate system
      Did anybody know how to bypass this bug?
      Or Tell me whats wrong?
      Thanks in Advance
        • Re: Api issue
          Dave Bear
          Hi Luigi,
          Have you tried using the magnifying glass (Search Bar) at the top right hand corner of the screen to search for relative posts about this. I'm sure you'll find something.
          Dave.
          • Re: Api issue
            Amen Allah Jlili
            Hi there!
            I have never been able to select the coordinates system in SOLIDWORKS. It's a design flaw of the API. I might be wrong. The thing is I don't really use the IMeasure interface because the results it gives are so ultraprecise (10^(-10m) precision) - which is something you don't really need especially if you're calculating perpendicularity between edges (for example) with a tolerances values in the 10^-3mm range - I have yet to see an application that plays at the angstrom level in SOLIDWORKS.
            If you're selecting a plane (IRefPlane), then you're having access to the RefPlane::CornerPoints property. This gives you four IMathPoint that belongs to the plane.
            Next, traverse all the features to get the coordinate system. Use Feature::GetDefinition to get the data object for the coordinate system feature (ICoordinateSystemFeatureData).
            This object has a property called OriginEntity. It will return Entity object. You need to figure what entity type this object is in order to cast into the right type and then get the coordinate or the origin.
            What is left to you is some simple math.
            Btw, this is blazingly faster than using Measure.
            Cheers,
            Amen
            CADHero.com
            • Re: Api issue
              Luigi Piron
              thank you everybody,
              i notice that i'm not be done clear with my question
              i'm in a context of assembly , i'm not in a part , and i need recursively take a measure beetween coordinate system inside a part
              and planes inside other parts
                • Re: Api issue
                  Amen Allah Jlili
                  A coordinate system has a transformation matrix that you can use.
                    • Re: Api issue
                      Luigi Piron
                      hy Amen you say truu
                      but if u have a component with a secondary coordinate system named for example "pippo" the transform Matrix
                      Option Explicit
                      Public Enum swUserPreferenceStringValue_e
                          swFileSaveAsCoordinateSystem = 16
                      End Enum
                          Dim swApp                   As SldWorks.SldWorks
                          Dim swModel                 As SldWorks.ModelDoc2
                          Dim swDocExt                As SldWorks.ModelDocExtension
                          Dim swSelMgr                As SldWorks.SelectionMgr
                          Dim swFeat                  As SldWorks.Feature
                          Dim swXform                 As SldWorks.MathTransform
                          Dim sAxisName               As String
                          Dim bRet                    As Boolean
                          Set swModel = swApp.ActiveDoc
                          Set swDocExt = swModel.Extension
                          Set swFeat = swSelMgr.GetSelectedObject5(1)
                          Debug.Print "File = " & swModel.GetPathName
                          Debug.Print "  Current coordinate system = " & swModel.GetUserPreferenceStringValue(swFileSaveAsCoordinateSystem)
                          Debug.Print ""
                          sAxisName = swFeat.Name
                          Set swXform = swDocExt.GetCoordinateSystemTransformByName(sAxisName)
                          Debug.Print "  " & sAxisName
                          Debug.Print "    Origin                    = (" & -1# * swXform.ArrayData(9) * 1000# & ", " & -1# * swXform.ArrayData(10) * 1000# & ", " & -1# * swXform.ArrayData(11) * 1000# & ") mm"
                          Debug.Print "    Rotational sub-matrix 1   = (" & swXform.ArrayData(0) & ", " & swXform.ArrayData(1) & ", " & swXform.ArrayData(2) & ")"
                          Debug.Print "    Rotational sub-matrix 2   = (" & swXform.ArrayData(3) & ", " & swXform.ArrayData(4) & ", " & swXform.ArrayData(5) & ")"
                          Debug.Print "    Rotational sub-matrix 3   = (" & swXform.ArrayData(6) & ", " & swXform.ArrayData(7) & ", " & swXform.ArrayData(8) & ")"
                          Debug.Print "    Translation vector       = (" & swXform.ArrayData(9) * 1000# & ", " & swXform.ArrayData(10) * 1000# & ", " & swXform.ArrayData(11) * 1000# & ") mm"
                          Debug.Print "    Scale                     = " & swXform.ArrayData(12)
                      this method doesn't work
                      how can i transform the coordinate system that is inside a component at the level of assembly ??
                  • Re: Api issue
                    Luigi Piron
                    Hy Amen , i need to verify the orientation of the secondary Coordinate system of the component in the assembly space , in order to verify if ,,,,,for example ....the z axis of the secondary Cs is concord or in opposite direction rispect the global Cs of the assembly.do you think is it the right method ??
                      • Re: Api issue
                        Amen Allah Jlili
                        I'm not sure I fully understand you Luigi. You can still apply the transform matrix on the (0,0,1) zee vector to get its orientation with the regards to the assembly's coordinate system? Actually, I think you can get the entity that make the zee axis for the coordinate system of the component, then you can transform it to the assembly to see its orientation.
