I have a 4-bar mechanism. I use mates to get several named configurations of the assembly. I want to put each of the assembly configurations in a single drawing. How do I import in each separate configuration into a single drawing?
You can create views for one configuration on one sheet. Now create copies of that sheet (the quantity would be dependent on additional configurations). Now simply change the view properties to use desired configuration.
If you've projected views then make sure you keep those child views configuration linked to parent view.
